Originally Posted by mcrews
must have pics!!!!
Must???
took a before & after yesterday however it was before I painted it. I also believe it is too flexible and will need a reinforcement bar behind it. Going to work on that before putting it back on. Then I'll get a fresh after pic.
Maybe you can give me some feedback on the width of this thing... had thoughts of getting out to the front fenderwell or more coverage but realized it would need more supporting framing behind it and bailed on that for this version. If there is any mpg improvement from this then I may revise it and go wider.
edit: Oh yeah, forgot to mention... it is not obvious it is there unless you poke your head under there. It sits far enough back so it does not look odd in anyway and should not impact approach angles while off road.
