Might want to try some BP gas. The newer insight runs at almost 11 to 1 compression with its dual spark plug iDsi ignition. Myself and a few owners notice with BP or mid grade gas it will pull more timing and not vary the rpm or cvt ratio that often under a light load vs regular or the cheap stuff. Ive been buying my gas at sheetz as its 3 cents off with a membership card, but I like the behavior better on BP fuel.
