Search some of the various specific forums: Excess moisture in the intercooler causing it to bog down, clogged cats, minor transmission issue.
Ford's sold a lot of these engines and most probably will run perfectly fine for a long time. But that doesn't mean you don't do your due diligence in researching known or possible problems.
Same thing with the new Ram 8spd auto... wait until it's out for a year and see how it stands up to real-world abuse!
If you're in Nebraska and the wind stops or you see a tree, pull over immediately and take a nap. You're having road hallucinations.
