Old 12-16-2012, 02:13 PM   #11 (permalink)
jamesqf
Originally Posted by Old Tele man View Post
...but, like Dirty Harry asked: "...you gotta ask..." how many Chinese transistors and IC chips are UP there in those GPS satellites?!?!
But it's never (AFAIK, anyway) the actual GPS system that has caused the problem in any of the drive-off-cliff-cause-GPS-said-so scenarios. That is, the GPS would have been reporting a perfectly accurate latitude/longitude/elevation position. The problem is that the mapping data does not correspond to what's on the ground.
I see this with lot with the dirt roads out in the hills around here. There are roads that aren't on the maps, there are roads shown on the maps that don't exist, or aren't quite where the map says they should be.
