Originally Posted by Cobb
Purchased 3 of them and got them in the mail. Got an extension cord Ive cut up and am ready to wire it in use a light bulb as a load and see what the voltage is on the output side. Just trying to find the pin out. Its square shape with a notch cut out on one side and all connectors are in one orientation except one.
Soon as I figure it out I will apply power, watch what I touch and take readings.
I assume you've got it figured by now, but just in case - the odd oriented pin is the +. The diagonally opposite pin is -. The other diagonal pair is for AC. That is, this is a bridge of 4 diodes. Two share a common cathode at the odd pin (+). The two other diodes share a common anode at the - pin. The mixed anode-cathode connections are at the other 2 connectors.
-mort
