Old 12-18-2012, 10:08 AM   #11 (permalink)
kennybobby
Southern Squidbillie
Don't use spade lugs...
Originally Posted by Cobb View Post
Thx, yeah I downloaded the pdf at work and noted the pins. I need to get some spade connectors and do this right so I dont shock myself as I realise its 100+ volts.
So I need a heat sink and fan like the older pc processors for real use? I was going to put it in a project box with a 120vac fan for cooling for testing purposes in the car vs the bench.
To do it right you will want to wrap the wire around the terminals and solder them, then cover with heat shrink tubing. They are rated at 50 amps average and 400 A peak. A sliding electrical contact is to be avoided for critical applications.
The Following User Says Thank You to kennybobby For This Useful Post:
Cobb (12-19-2012)
