You can use blue painters tape to protect the original surface then cover the surface in aluminum foil, which will obviously not stick to the blue tape and therefore release when you are done foaming. Tape the aluminum foil down where it will not stick or conform on its own ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
