Thanks, yes there is a plywood grill block and a partial belly pan. So after sitting for 4 hours with the outside temp between 0-5 degrees the coolant was at 24 degrees. I took a bunch of temps throughout the 4 hours. I will post all the numbers tomorrow after going without the cardboard
