Hey guys.
I am in the middle of building my own generator but not from any purchased plans. I researched a couple designs and choose one to start off with. I also bought a scanguage to get some data for an A-B-A test of my build. I plan on trying a simple mod to send a slightly higher voltage from the o2 sensor to the ecu to make sure it leans out. Also going to try to retard the timing if needed.
The only way this will work is if the hydroxy gas makes burning gasoline more efficient to make up and exceed the electrical losses in the generator. We will see.
I am waiting for the correct electrolyte, aka, NaOH (sodium hydroxide) or KOH (Potassium hydroxide). These are cheap as well but you either have to order them online or have a soap making supply shop near you.
