Old 12-19-2012, 11:14 AM   #70 (permalink)
slownugly
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
haha dont get me started on wrong parts. there is such an inconsistency in the auto parts market today its ridiculous. even somthing as simple as an outer tie rod end our supplier will send 2 tie rods up with the same part number on both boxes. both boxes will be exactly the same yet both tie rods look nothing alike and one has a grease fitting the other one doesnt. what can ya do. the stupidest one i have seen so far is i did a flexplate in a late 90s chrysler van. very common problem. i got the trans back in had almost everything hooked back up and i was installing the torque converter bolts and the morons drilled the holes wrong for the torque converter bolts.
