Received my pre-made ABS grille insert pieces today. Installed them at the post office parking lot (bolt on). Noticed that both coolant and oil temps ran slightly higher (good), but as A/C was on, was happily surprised that those temps rose no higher than they did (Ultragauge). Enough air flows through the non-grille areas of the front end that I am pleased. Hope that the OP finds his to be "good" in some similar manner. I have a "winter front" soon to be delivered that really closes off the heat exchangers. With a 1k road trip commencing tomorrow -- solo & towing -- I hope to find "the range" of using the grille block.
