Originally Posted by christofoo
If you want to use this in traffic, being seen by cross-traffic when you have right-of-way is a serious concern with all recumbent-type vehicles. Consider 500-2000 lumens of forward motorcycle / LED lighting. Needs to have a bright mode for daylight and a directed road pattern for nighttime. This issue gets a lot of discussion in bicycle forums.
Just cause I'm still logged in, I'll reply right away.
First, I would like to use some sort of bright paint job. Safety green is a bit conspicuous but maybe a nice 70's blue or lime green.
http://static.corradoworld.com/pictu...ciroco_MK1.jpg
http://farm9.staticflickr.com/8152/7...24b9f49d_z.jpg
It would also need ample reflectors- probably the kind that look black until you shine a light on them- over the "painted black" areas.
Last, I would have LED running lamps. It might be good to make them flash like some motorcycle headlamps, and since it will be registered as such, that would be legal. Not sure how to go about putting together the lighting- do you know of any good threads?
