Originally Posted by AeroModder
They're 1" lowering springs from ST Suspensions. It doesn't seem like there's any significant gains, but they do seem to help a little bit on the freeway. The handling boost was desperately needed with how soft the stock springs were. I'm also doing a battery relocation for better weight distribution so I can better help "conserve momentum" around corners.
Yep when I exit the Interstate and "conserve my momentum" around the cloverleaf, the Subdivision that was all over my arse, coasting down to the exit ramp, without ever touching the brake, is about halfway through the cloverleaf when I finish the exit ramp and enter the road. One of the more enjoyable parts of hypermiling, the conservation of momentum
regards
Mech
