Old 12-20-2012, 08:31 PM   #28 (permalink)
user removed
Originally Posted by bondvagabond View Post
Engine 6 Cylinder Diesel OM 621 190Dc:
Capacity: 1988cc 121.27ci
Type: Diesel, watercooled four stroke, reciprocating piston type with 6 cylinders
Configuration: Front mounted, longitudinal, inline
Head: Pushrod and rocker actuated ohv with one valve per cylinder
Fuel System: Bosch injection pump (pre-combustion chamber)
Bore and Stroke: 3.43 x 3.29 inches (87 x 83.6mm)
Power: 55 hp (DIN) @ 4200rpm
Torque: 11.5 mkg @ 2400rpm (87.0 ft/lb)
Compression Ratio: 21.0:1
Pretty sure that motor is SOHC with rockers on ball pivots. No pushrods.
regards
Mech
