Old 12-21-2012, 04:58 PM   #10 (permalink)
radioranger
radioranger
you've got some pretty smart guys here, just remember run all the power through a fuse first, maybe somebody could draw a schematic to release the current when the brake lights activate. two relays should do it , if the current flows through the brake light it activates a relay the contact of which open to turn off your magnet till you re trigger it, on the magnet side of it you could even wind your own and maybe add a small steel plate on the throttle plate arm to mount it . Good luck.
The Following User Says Thank You to radioranger For This Useful Post:
Stacygifford (12-21-2012)
