Old 12-22-2012, 01:34 AM   #11 (permalink)
2000neon
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
To activate the system with the brakes, instead of going from the brake lights,you could most likely go straight from the brake light switch. If the make/model of your vehicle had the option of cruise control than your brake light switch likely already has a terminal that is activated (or deactivated) when the brakes are applied, to shut off the cruise control.
I uses this when I installed a lock up torque converter in my El Camino, as soon as I applied the brakes, the "cruise control" terminal of the brake light switch would automatically disable the cruise, but I use it to unlock the converter.
If your car does have the option for cruise, this would be a decent way to have a factory connection/ switch.
The Following User Says Thank You to 2000neon For This Useful Post:
radioranger (01-23-2013)
