Old 12-22-2012, 10:31 AM   #4 (permalink)
chrisgerman1983
chrisgerman1983 - '96 chevrolet astro
90 day: 14.02 mpg (US)
I like the looks of the piping for grill block on your truck. I think it would be a lot of trial and error to get the spring rates to work out, that would be the only problem I see. but you could set up a camera to see when they close and open. For me I think that a temperature controlled opening would be easier to fabricate. Or you could still use the piping and and use a vacuum diaphragm that you could salvage off an old furnace. That way under heavy load the block could open? I am mostly just thinking as I am typing but that is how brainstorming works right?
The Following User Says Thank You to chrisgerman1983 For This Useful Post:
BamZipPow (12-22-2012)
