Old 12-22-2012, 12:34 PM   #7 (permalink)
whitetoy
In my Honda, the cruise control is a small box under the hood that has a cable attached directly to the gas pedal - it doesn't touch the throttle cable. I'm willing to bet I could grab the CC servo out of a car like yours and make it work in mine though.
If you already have factory CC, I wouldn't mess with it. On flat highways, it would work almost as well. The servo unit from the Camry is pretty big and might not fit under your hood. Your Honda throttle cables would not be compatible, or be the right length, either.
