seems like a clean design although i think it will pop off on you , maybe better to pull the wheel and get a washer to fit inside and out maybe fender washers would fit for you , and put a bolt right through then a washer either side of the pan , followed with an acorn nut to clench th edeal, look up mcmaster carr for all the hardware they are great on nuts bolts and all kind if fasteners even metal etc, great site, every imaginable size washer,
