Old 12-23-2012, 12:06 AM   #8 (permalink)
arcosine
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
No, the Saturn is geared taller than the insight and has 100 hp at 5000 rpm, doesn't have variable cam timing, is 500 lbs heavier, not including wife, two tool boxes, 2 cats, a welder, a tow bar, and other stuff that was as additional 400 lbs on this trip. It is at 2042 rpm at 65 mph.
Yes, it should have a switch to tun off the electric motor and a turbo for boost up hills.
I'll put some injector cleaner in it to see if it helps. How do you know when it is in lean burn mode?
- Tony
