Yes, when you're concerned with temps, just keep an eye on the coolant temp. When starting up, the temp should continuously rise until the thermostat opens (typically 180-200 deg F), and then fluctualte slightly within a range of +/-10 deg F or so. If the temp starts to rise above that level that means you have too much grille blocke--because the engine can't stay cool enough with the stat full open. If that happens, start taking grille block off.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
