Old 12-24-2012, 09:50 AM   #93 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by puddleglum View Post
So, do you know yet where this controller is going to end up for output specs? I got that you are planning for 1000 amp peak. What do you think the continuous rating will be? esoneson posted that the components are rated for 400v. What do you think a realistic upper pack voltage will be? Are you still thinking a 144 volt limit or are you hoping that this may be more comparable to a Soliton?
The IGBT's are rated for 600V and 400A each. The controller has been tested over 220V without any issues. It is designed to handle a 300V nominal pack. As long as you stick to around 400V at peak, you should be fine.
As for output current, The controller is design for 1000A continuous, not peak. As long as the water cooling keeps up, which it should, you can get 1000A all day long.
The controller was designed to be comparable to a Soliton. Infact, it uses the same brand capacitor.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
