12-24-2012, 07:12 PM
Can I haz Coroplast plz
Originally Posted by Smurf
In short, yes. Many cars take ~15-20 minutes to fully warm to temp. Transmission is still cold as well.
Are you able to control the shifting with that automatic?
Yes, the Genesis coupes with Automatics have the Shiftronic (R) http://images.gtcarlot.com/pictures/51951751.jpg . You can move the shift knob to the far bottom left and then it acts like a joystick that lets you move it up and down to go up or down in gear. When you shift the knob into the auto-manual mode from drive, the display in the dashboard then goes from "D" to the number of the gear you are currently on and go up and down as you change gears. Additionally, the steering wheel has levers on the left and right for changing the gears from your fingers as you hold the wheel. I noticed that I can go up in gear sooner if I have auto-manual engaged.
