Originally Posted by kennybobby
If you do anymore runs be sure to record the acceleration time in seconds--without that we cannot calculate the power level of operation. e.g. 0 to 70 kmh in ?10 seconds, 15?, ??? seconds. The quicker the acceleration time then the higher the power level.
ok i will record the time to 70kmh next time. but if power is of interest, here is a dyno from when car was stock at WOT. AFR stays lean until 3500rpm.
