Old 12-27-2012, 04:07 AM   #11 (permalink)
serialk11r
Originally Posted by turbovr41991 View Post
I had this transmission in my 1986 mr2. Took a little modification to make it work in the mid engine setup, but worth it. Like it alot. It is a little different than the C60 and is intended for the A block (aka 4AGE).
I sold mine for $500. Most seem to get 500-700 latley
It IS an A engine. The Blacktop 20 valve is part of the A block series. I had this trans mated with a stock MR2 engine and the 99 blocktop 20 valve 4age. Both worked flawlessly. It is also a drop in swap for a corrola.
That's what I said, not a non-A engine. Double negative.
Oh so the C160s are cheaper than the C60s? Interesting. I wonder if they bolt up to 1NZs easily, in case I ever get rid of this horrid 1ZZ POS.
