Old 12-27-2012, 12:50 PM   #7 (permalink)
samwichse
Thalmaturge
CHONK - '18 Honda Clarity
Peter made a demo!
Imac&c hch1 civic - Page 37 - Insight Central: Honda Insight Forum
Just gives you basic 1 click assist and regen, but you can play with that at no cost at all if you build yourself a breadboard version of the device. Note I used a 5-way switch from Radio Shack instead of the three separate buttons (didn't work very well), but here's mine from before he had the permanent circuit boards etched:
Not a super complicated device if I could figure it out this circuit diagram with no electronics experience at all except building an ice tube clock kit from Adafruit:
Parts list (Digikey) is here:
https://docs.google.com/spreadsheet/...lh5aWlJRFBac2c
Add that to a breadboarding kit from Radio Shack and you're all set to start playing with MIMA. Plus the parts you use in it can easily be reused if you decide to buy the silkscreened board/software. Again, what I did originally.
Sam
The Following User Says Thank You to samwichse For This Useful Post:
Cobb (12-27-2012)
