My Ebrake on the cx only holds one wheel. Are you sure it's the throwing bearing? If you take out the trans put a clutch in it. The input shaft bearings are notorious for going bad also. I think If I took out my trans I might put one in just cause. I mean I'm already there. good luck on the defost. The element is probably bad. Disconnect both feed wires and check for continuity. The axle seals are cake as are the axles but they have to come out to do a clutch so....
