Old 06-14-2008, 11:23 AM   #1 (permalink)
trikkonceptz
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
My Experience w/a 2009 Ford Fusion
In my quest to reduce my oil dependency, I am going to trade in the family truckster 06 V8 4-runner, for a 2009 4cyl 2.3L Manual Fusion. Therefore because I work @ a Ford dealership, I figured I would take one home for the night to show the wife and see what potential this car really has.
First of all it is a very comfortable and quiet car, I really did enjoy the 120 mile drive I had in it and feel it is a quality automobile, plus with my employee discount, a mid size 4 door sedan for under 19K isn't bad either. It will literally cut my car payments in half...
Anyhow, sticker on this bad boy said 20 / 29, so I figured I would see what driving techniques alone would do to FE. I didn't check my tires, but they nitrofill here at the dealership to 35psi (I checked this morning).
Here are my results.
Home Trip; 37.6 mpg on Scangauge
-55mph on hwy
-Pulse and Glide whenever possible (Pretty cool too, I'll explain later)
-Coasting to stops whenever possible (Car glides very well)
-Engine off @ Idle only
-A/C off, night was cool
Trip to work; 37.7 mpg on Scangauge
-55mph on hwy
-A/C ON ENTIRE TRIP
My observations.
-The car shuts off injectors when coasting in gear
-It must have an improved a/c clutch because to see no change in mileage is incredible
-Pulse and gliding looks like it doesn't work until you see your average mpg raise a couple ticks each time you do it.
Now for pulse and glide I set the cruise @ 55 and used my LOD to monitor acceleration to 65 then let off, rinse repeat. I don't know if that was optimal, but it delivered some pretty good results.
So in conclusion, with a few more tweeks this is a vehicle that I know I can break into the 40+ mpg mark with very little additional effort.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
