Im debating on buying a new iacv.the reason for my idle not dropping normally was the tps was wayyyy off on the calibration. 1.45 at closed throttle. Now the iddle fluctuates up and down a little over 1k rpms but stops at a complete stop.iv taken it out and cleaned it several times.my radiator is leaking .cud off coolant pressure thru the iacv cause wierd idling issues as well?
