Old 12-28-2012, 02:32 AM   #100 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by RatherDashing View Post
at neutral theres a slight constant grinding noise.when the clutch is engaged the grinding stops.when in gear most of time time its not grinding.if it does its at lower gears and gets a little louder almost sounds like its stretching.
From what you are saying there is no way it's the throw out bearing, if it was the throw out bearing then it would only make a bad sound when the clutch pedal is pressed in and it would go away when your foot is off the clutch, what you are describing is a bad input shaft transmission bearing, that bearing going bad will wear your clutch out faster as well, but it will take a while, I put thousands of miles on mine after the bearing went bad, of course I went the route of spending $150 on a low mile, used transmission to fix it as well instead of replacing the $15 bearing.
The Following User Says Thank You to Ryland For This Useful Post:
California98Civic (12-28-2012)
