Originally Posted by Frank Lee
it took pee longer to type that post than it would have taken to make a blanket and feel the heat retention.
Blankets have very little R value actually.
While there may be a slight increase over not having a blanket, you are actually just blocking the heat from the sun.
In addition, wrapping yourself in a flammable material when you may near a stove or smoking is not a good idea.
100mm of fiberglass strand insulation surrounded by an impermeable vapour barrier would be a better idea!
