Old 12-29-2012, 11:40 AM   #26 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by pete c View Post
Would love to have one of those first gen CRXs, but only if I could make all that spaghetti BS go away. Fortunately they are over 25 years old, which exempts them from emissions. Is there a way to get rid of all that garbage? Maybe an aftermarket weber? Would that harm FE?
Getting rid of the 52 vacuum lines is a great way to destroy the engine, the CVCC engine doesn't have the spark plug in the normal combustion chamber, it's in a little "pre-chamber" that is fed by the 3rd barrel on the carb, it also tends to have an o2 sensor that controls the carb via vacuum lines, it has deceleration fuel cut off that is controlled via vacuum lines, it has a factory warm air intake that is controlled via vacuum lines, there is not a single vacuum line that I can think of that does not help it get better mileage, help it run better or help keep it from running lean and damaging the engine and in the 3 cars with CVCC engines that I've owned, I only found one vacuum line issue and that was caused by me messing around with them
