Old 12-29-2012, 01:08 PM   #9 (permalink)
chrisgerman1983
chrisgerman1983 - '96 chevrolet astro
90 day: 14.02 mpg (US)
Originally Posted by radioranger View Post
I understand that the ribber compounds all have oil and carbon in them and the rubber eventually evaporates and leaves behind the harder materials, also much less traction on even almost new looking old tires, so i'm sticking with new, buy a lot of gas for what an accident costs,
I agree, I don't think you should let your tires sit around for years. I just question weather allowing the tire to cure a little longer may be beneficial? Paint, lacquer, adhesive are all dry to the touch in hours but have a much longer cure time. Latex paint will ball up if you try sanding it for repaint within a couple months of application. Most autobody shops advise waiting a couple months before waxing a new paint job. I have tested silicone adhesive at work and silicone that is allowed to cure for a year is almost impossible to remove but even silicone allowed to cure for a month or two can be removed very easy.
