I appreciate all the input. I especially loved the long answer, thanks. I am thinking about trying the 225/60's as they are not that much bigger. I do hot rod the car a bit at times, and the wider tire should definitely help cornering. And the issue with the back tires is they are going flat due to dry rotting. My dad worked for Goodyear for almost 30 years and informed me that the cheaper tires are more prone to dry rot than the better made tires. It would be interesting to see how big a difference there is between the batches.
