Thread: Tires and Rims
Old 06-14-2008, 02:50 PM   #23 (permalink)
aerohead
tires and rims
Originally Posted by abshnasko View Post
so in conclusion (correct me if im wrong):
1. a larger rim + tire combo CAN be lighter if attention is paid, helping FE
2. larger rim is generally less aerodynamic and takes a wider tire, hurting FE
3. larger rim size means that more of the LRR tires will fit (possible negating the effect of #2?), helping FE
4. larger rim and OD reduces rpm's, helping FE
about a larger rim being less aerodynamic... would some of this be countered some if I installed dams in front of the wheels? Or would it have to be skirts...
(1) Right! If the overall mass is less,and the mass is not concentrated out near the tread,the wheel/tire will be lighter "flywheel". (2) the larger rim need not be less aero if it is more like an optimized disc ( pie-pan ).If the wheel is WIDER,then it will a larger frontal area,crashing into more air as it goes. (3) yes,although it didn't work for me in the case of the Michelin MXV Green-X radials. (4) Only a larger overall circumference of the tire will effect revolutions per mile,and typically,in a clean-sheet design for a high-mpg car,engineers would spec out a slow-turning tire for the LLR.
