Old 12-30-2012, 06:19 AM   #15 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
Originally Posted by Sentraguy View Post
.....My biggest question, which was unanswered by a search of ecomodder and google, is if it is even worth it to change tire size on a car that has an automatic transmission......
I think the data says there is only a little benefit from changing tire size. Plus, there is limited room in the fenderwell and you just don't want anyhting rubbing. Put a different way, unless you are sure there is room for larger tires, the risk of doing it wrong outweighs the potential benefits.
However, there is a HUGE benefit from carefully selecting tires for the properties you want.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
