Originally Posted by aerohead
The Matrix body type does not generate lift.So since the up-kick on the wing would generate downforce,that type of wing becomes a solution for a problem the Matrix doesn't have.My guess is that it's a "Rally-inspired" concession to styling.If they make one ( as others have mentioned already ) that follows the original roof and side contour,that would be the one to go with.
How do you know for sure it doesn't generate any lift? The profile resembles a wing shape to me. Anyway, the problem here is the perspective of the photo. It's shot from ground level giving the appearance that the spoiler tilts up. The rear edge actually winds up horizontal, or parallel to the road surface; which is what you want when breaking airflow away from the body to reduce drag.
