Old 01-01-2013, 09:20 PM   #5 (permalink)
1337
In hypermiler central
[SOLD] Highway Warrior - '00 Mazda Protege LX 1.6L Manual
90 day: 35.93 mpg (US)
Basic Miata - '06 Mazda Miata Touring
90 day: 30.93 mpg (US)
Send a message via AIM to 1337
Originally Posted by mcrews View Post
Check the rear end gear ratio.
That may be the difference......And that's something you could swap uot.
Also, if you can upsize the tire, you could close that gap!
Good point. The 2.0L and 2.3L manuals have the same gear ratios. The final drive ratios vary slightly from year to year. In most years, the manual final drive ratio is shorter than the automatic. Only for 2004, the 2.0L has a shorter final drive ratio (3.683) than the 2.3L (4.416).
I wonder if the final drive ratio from the automatic can be swapped into the manual version.
I think the 2.3L manual's 4.105 final drive ratio could be replaced with the 2004 2.0L 3.683 final drive ratio.
Ah, it would be awesome if the differential were at the rear end. I wish there were a reliable, fuel-efficient, underpowered, good-handling RWD wagon on the market. Sigh.
