Old 01-02-2013, 06:02 PM   #95 (permalink)
FieroChris
Hi Adam,
I have a few questions,
are you using 1/2 of the IGBT ?? since this is a dual unit?
also do you have a system wiring diagram ??
I am trying to understand the location of the huge cap in your photos, is this across the switch ?? on the input ?? or on the output ??
have you considered making your board be splitable, ie, all the driver parts are at one end so if a user only needs 400A they can cut the board off 1/3 of the way down, 800A 2/3 etc...
have you posted the gerbers for the IGBT driver board yet ??
if you do I will send out for several to be made for my project
thanks
-chris
