ECU ignition timing and fuel curves are the likely "culprit."
I've found that a short "blip" of the throttle while at cruise speeds will advance my timing from it's typical 29-32 degree advance, up to 39-41 degrees, and will continue to stay there while at a constant speed, allowing less fuel to be required for stoich 02 parameters.
'97 Acura CL 2.2L 5spd
'03 Honda CR-V 2.4L EX 4wd Auto
