Old 01-04-2013, 03:37 AM   #1 (permalink)
jabb
Sharon - '00 Fiat Punto ELX JTD
90 day: 42.76 mpg (US)
Fiat Punto Mk1 1.2 MPI - Now with airdam
I am currently driving my second Fiat Punto MK1.
I've already made 2 grille blocks:
large one is held on with zipties and is formed with heatgun so it fits the shape really well
the narrow one in the upper inlet is just a push fit, held by magic and good will and it's not covering 100% of the area so that the engine doesn't overheat.
Yesterday I've had some time to work on it in a non-repair way so I've put together an airdam out of some steel (L brackets), few screws, nuts and bolts and of course 2 scrap strips of plastic that were leftovers from information signs. Plastic type is unknown, it's pretty soft and easily dented but shapes really well with aid of knife and heatgun (early xmas gift from me to myself). It's the same material as the grille blocks.
It's only held on 3 brackets and the plastic strips overlap so I've bolted them together to improve stiffness. There's around 10 cm of space between my airdam and ground.
I don't believe it'll live very long with the amount of potholes we have here.
I don't have any scientific way of testing it either since I've no way of plugging in scangauge, I can't fill the tank to the top since the inlet pipe is leaking a bit.
I basically fill it up with ~18,5 l (100 zł worth of fuel) and see how long it takes to get the needle between 2 rectangles on my fuel gauge.
I'll see if I can beat my best of around 5,5 l/100 km.
I'm also looking for less road noise but that's even harder to judge.
So guys - I know it's not a looker but do you think it'll do some good? How much improvement can I expect (if any)?
ID:	12201   Click image for larger version
ID:	12202   Click image for larger version
ID:	12203   Click image for larger version
