Old 01-04-2013, 07:27 AM   #9 (permalink)
justme1969
justme1969's Avatar
also possible that it buit up in cat conv. if you stalled just b4 the test several hundred times as you said.
then when cat heats up unburned fuel burns off.
always get engine hot prior to test, and run it out a little if egr is sticking WOT sometimes pulls it back.
The Following User Says Thank You to justme1969 For This Useful Post:
AaronMartinSole (01-04-2013)
