So it begins
Finally used up my Lucas UCL so that I can re-use the bottle for the TC-W3. Added to my car finally.
Tip 1: If you are using a clear bottle for measuring, with graduations, shake it a few minutes before you go out to car, so the blue color can settle back into bottle and not block your view.
Tip 2: Squeeze the Lucas bottle less than you would for the original Lucas product. TC-W3 is thinner, & more comes out per squeeze.
Tip 3: Check often if using this method, so as to not overdue it: 1 oz per 5 gallons.
