Old 01-04-2013, 11:37 PM   #14 (permalink)
oil pan 4
Cheap generators will only run for maybe 200 hours before you have problems with them.
The cheapest way to get a high voltage DC charger that I can think of is to use a 220v Varrac and set up an array of bridge rectifiers. One that has an input voltage of 220v and has an out put range of 0 to 300v. The decent sized varrac like I have can handle 5kw. But you would need a real generator that puts out 220v power, 110v power would work at greatly diminished capacity.
If you don't know what you are doing this can also be a quick way to die.
Turbine powered generaters suck fuel like you wouldn't believe, I work on those too.
