Old 01-05-2013, 01:48 AM   #2 (permalink)
some_other_dave
If the engine has electronic fuel injection, and if it has some sort of electronic speed sensor, then you should be able to hook an MPGuino in to it. It requires some doing (you may have to build the MPGuino yourself, you will have to splice into some wires to hook it up) but it will give you instant MPG feedback like the Scangauge does.
-soD
