Originally Posted by deathcomesarippin
the t-5 is great! If you have 3.08s do still have the 8.8 rear end? do plan on changing the rear gears? If you want to get serious ($$$) id swap out for a good 9 inch, probably could weigh less.
the 9 inch is considerably heavier and way over kill. if you decide to put a 8.8 in make sure its a 31 spline other wise ther isnt gonna be a big difference in strength to justify the weight cause the 7.5 and 28 spline 8.8 use the same axels. secondly a 7.5 can handle some serouse power i had one behind a turboed 2.3 in a ranger that put down 467hp at the wheels and was never babied oly reason i went with an 8.8 was got a good deal on it
