If you have indeed chaecked everything mechanical ... like sensors tune ups etc ... I would consider a quality grounding kit. My old 96 Civic always ran rough at low idle then it dawned on me that the vehicle had only 2 crappy ground cables. I built my own tuner like grounding kit and the car began to pur like a kitten from there on.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
