Did you end up fitting your larger core radiator and the additionnal VFR one ?
All the extra cooling capacity of the world is not gonna help if your thermostat is set to a high value anyway ...
And you stated somewhere you didn't like the temperatures of the bike although it was still in the 'normal' range.
An engine performs best for FE when it is on the hot side ...
