Old 01-08-2013, 06:33 AM   #5 (permalink)
AndrzejM
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Hi,
You may try some of those mentioned here: Hour Meters, Gauges
And here you can find a discussion regarding the issue: Installing Hour Meter - Source of +12V when engine is running? - Insight Central: Honda Insight Forum
It's quite simple you need two hour meters one hooked up to the ignition to measure whoe time of car running and second one hooked up to oil pressure switch to measure engine's running time. Then you have everything that you want.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
Weather Spotter (01-08-2013)
