I used to have an S-10 blazer 4wd with a carburated six cylinder and I swapped out the motor to a tuned port, fuel injected 350 v8 from an Iroc camero. I remember the stock gas tank had an electric fuel pump in it, but it was a low pressure pump, so I had to swap the hi pressure pump from the camero into the S-10 gas tank. The gas tank was pretty easy to take out, so you should be able to get one cheap. I don't know if it's fuel pump will handle deisel though.
